Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 03-09-2010, 05:02 PM
Dawgfan Dawgfan is offline
Dyno Result for my GTS
Went to the Dyno today for the NASA season. We had a 358 hp at the Rear Wheels and 438 at the Fly Wheel reading and I don't think that's to bad.
Old 03-09-2010, 06:51 PM
panozracing's Avatar
panozracing panozracing is offline
Re: Dyno Result for my GTS
Is that a sealed Panoz GTS engine? Is that with all the updates allowed?
Seems like too much drivetrain loss. I would expect the 440 FWHP but the RWHP should be around 400. Right? How was FWHP determined when you are using a chassis dyno?
Our motors are 500 FWHP checked on an engine dyno and 450 RWHP on a chassis dyno.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 03-09-2010, 07:24 PM
My engine is from Elon, it is a 351 Winsor. The guy at the Dyno said you figure 20% to 25% for the FWHP. That is what I am basing this on.
Old 03-09-2010, 07:34 PM
do you have all of the Panoz engine upgrades? Long tube headers, proform carb upgrades, cowl induction, etc.?
Panoz claims more HP. I would have expected about 400 RWHP from a Elan sealed motor?
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 03-09-2010, 07:46 PM
eric1h eric1h is offline
i swear we have a ton of drivetrain loss in these cars either from the rear end, tremec tranny or all of the above.
Still nice numbers comparable to what i'm running with The Panoz. Zooooooooom
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
NZGTRA17 NZGTRA17 is offline
For conversion from rear wheel hp to flywheel for Dynojet dyno's I use a conversion factor of x 1.17.
So on a Dynojet dyno if a sealed GTS engine is 440 flywheel hp it should be 375hp at the wheels.
What sort of dyno was it? What was the torque reading at the rear wheels? Likewise for your 427's Brian, what torque are they at the wheels when in 450 rwhp trim?
Kel M
Panoz GTRA #17
New Zealand
Old 03-09-2010, 08:43 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
I'd think you can get from 358 to 375 by fiddling with jets and timing. That number sounds in the ballpark; dyno variations notwithstanding...
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
Old 03-09-2010, 09:38 PM
Attached are the last dyno sessions we did with both 390 carb and the 650 carb. As you can see from one car to the other and from dyno to the other the results VARY. This really annoys me since my class in NASA is a dyno based racing league and I cannot tune with any kind of confidence. Could you imagine me dyno tuning the car in Florida, buying a special built carb to get as close as you can to the allowed limit and then go to nationals in Utah and their dyno reads illegal? Now what? When we got dyno checked in Ohio at nationals their dyno read 420 RWHP with the 390 carb which is 30 HP less than the "SAME" dyno in Florida.
390 CFM #4 DynoJet
390 CFM #23 DynoJet
650 CFM #4 DynoJet
650 CFM #4 Some other dyno (I forgot the brand)
390 CFM #4 Some other dyno (I forgot the brand)
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 03-10-2010, 06:16 AM
I will get the info on the Dyno today and also go over to Elon and talk to them and see what they have to say. This engine only has 6 to 7 hours on it, so I'm sure Elon will talk to me about it.
Old 03-10-2010, 06:39 AM
David Eastman David Eastman is offline
How about some photos of the new car.
Old 03-10-2010, 12:56 PM
Thanks Brian, very interesting. Yes it is pretty hard to run on the edge with inconsistencies like that. I guess all you can do is learn from year to year and anticipate the benefit offered by one dyno over another. The inconsistencies are the very reason I always use the same dyno every time I tune the car.
Love that 427 torque curve. I am guessing it would be pretty hard to harness that much torque with DOT's over an endurance race - even with the likes of 315's. Rear tyre heat/wear would definitely be more of an issue!!
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 03-10-2010, 06:02 PM
Went to Elan and talked to a very impressive guy that showed me all around Elan. He says that my engine should at least make 400 hp at the rear wheels. Will start the weekend at R A and work on it as we go. The Elan pro says it could be the timing, fuel mixture or the jets in the carb. Will give update and pics when available.
Old 03-11-2010, 08:40 AM
Do you have long tubes? i forget?
Old 03-11-2010, 06:47 PM
I'm not sure. I will let everyone Sunday how we do. It will be and allways is a great weekend to load up on Sunday as good as you look unloading on Friday.
Old 03-11-2010, 06:59 PM
Getting an extra 42hp from timing and jetting is possible but the setup would have to be quite a way out now. Going from 302 to 347 my engine made 373hp / 368tq with the carb jetted to suit the 302. 1 size up on primary jets & 2 sizes up on mains and the 347 was up to 388hp / 392tq (with aircleaner fitted).
Some of the difference may be from a different type of dyno or something about the way the car was dynoed such as running the car without the air cleaner on, not properly up to temperature etc (my car picks up approx 15ftlbs of torque and 10hp at the wheels with the aircleaner & cold air tray fitted). I wouldnt sweat it, main thing will be that it pulls well on the track and has similar pace to other well sorted GTS's.
Kel.
Kel M
Panoz GTRA #17
New Zealand
