Old 03-09-2010, 12:50 PM
95stang50 95stang50 is offline
94 accord slight misfire
I have a 94 handa accord 2.2 sohc with a 5 speed. I just bought the car and changed the plugs,wires,cap, and rotor. It seems to have a misfire at 1750-2250 rpms, only when its up to temp. not when its cold. . It dosent seem to be when i am climbing through the entire rpm range. But when i am crusing between 1750-2250 it has a misfire. I dont know much about imports any help would be great Thanks
Old 03-09-2010, 02:07 PM
somick's Avatar
somick somick is offline
Re: 94 accord slight misfire
May be a fuel filter...
Try to run a fuel injector cleaner.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 03-09-2010, 07:23 PM
mpumas mpumas is offline
Pull your sparkplug wires off the plugs and check for oil.. If the plug tubes are full of oil, you can get a misfire.
Old 03-10-2010, 04:28 PM
I have replaced fuel filter,pcv valve, air filter, plugs(with correct gap), plug wires,cap and rotor. There was no oil in plug holes(amazingly it was bone dry). I have ran a couple cans of fuel injector cleaner through now with no results. I am still sumped. It only seem to do it all the time, dosent matter if its hot or cold. . Also it only does i when i am accelerating very slow or at one speed from 1750-2250.?????????????? who knows?????? I am going to clean everything i can see in the throttle body and see if that will help. Thanks
Old 03-19-2010, 02:25 AM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
are there any codes? I've heard of a guy who had similar problems, and the solution was in the EGR.. worth a look i guess... thats a tickler. though i'll have to think about this one
