Old 03-09-2010, 09:00 AM
CivicLeader's Avatar
CivicLeader CivicLeader is offline
Send a message via AIM to CivicLeader Send a message via Yahoo to CivicLeader
flywheel replacement tutorial - '94 k1500 auto 4x4
Z71
Is there a tutorial out there for this... I'm getting a quote of about $450 to replace the flywheel but if I can do it myself, I'd rather do that...
Thanks,
Rod
Old 03-09-2010, 05:52 PM
Re: flywheel replacement tutorial - '94 k1500 auto 4x4
Anyone????
Old 03-10-2010, 12:02 AM
2000CAYukon 2000CAYukon is offline
This is a very basic description http://www.ehow.com/how_5272678_repl...nsmission.html
A Factory Service Manual would be more specific.
//2000CAYukon
Old 03-10-2010, 07:59 AM
//2000CAYukon
Great step-by-step but will it change working on a 4x4... from what I've been told, basically the only difference is that I'd need to disconnect the drive axel leading up to the front axel...
...excuse my loose usage of terminology
Thanks...
Old 03-10-2010, 08:07 AM
Also, should I go ahead and replace the starter when I do this... I did put in a new starter from AutoZone last year and now I'm having thoughts that this starter might have caused the problem...
I had a hell of a time getting the starter installed correctly... with/without shim's... According to AZ, it was the correct starter but we can safely assume that they probably just don't know what they're talking about...
Thoughts?
Old 03-10-2010, 08:54 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Thoughts?
You did not say what was bad with the flywheel.
If flywheel teeth are bad or starter is noisy or acting up yes replace the starter with an new flywheel.
And use the good quality lifetime starter not a 90 day wonder.
On replacing flywheel it is either pull engine or transmission.
The actual time and word depends.
Depending on the tools you have and transmission pulling and or engine pulling equipment you have.
Also make sure the engine is not kicking back on starter causing problems in that are.
MT
Old 03-10-2010, 09:05 AM
There are sections of the flywheel where the teeth have been chew'd up so that's why i'm replacing it...
yeah, I'd rather pull the transmission then the engine...
I don't believe the engine's kicking back on the starter... runs/start's pretty smooth...
Old 03-10-2010, 10:14 AM
MT-2500's Avatar
AF - Advisor
Go for a good quality starter with the new flywheel.
Good Luck and let us know how it goes.
MT
