Old 03-08-2010, 07:22 PM
leftys4js leftys4js is offline
is it a security issue
hello my son has a 99 grand am 2.4 we installed an after market pioneer stereo in it using a scoche wiring harness and the stereo wiring diagram..the issue is whenever the battery is disconnected or needs charged due to leaving lights on etc..the stereo quits working i have to remove it and unplug the wires from the stereo and replug them back in and reinstall the stereo and all works great again..i am pretty familiar with stereo installations so positive its connected properly. any help or suggestions would be aprreciated thanks
Old 03-13-2010, 04:22 PM
mcmalloy mcmalloy is offline
Re: is it a security issue
i would say the stereo memory dont work, take it back and get a differnt one
Old 04-09-2010, 09:21 PM
thephantom1492 thephantom1492 is offline
Scorche GM module with chime?
I have a simmilar problem with mine and I'm planning to replace it.
Basically, if the battery voltage drop too much while cranking the module crash! And then the radio don't turn on. To turn it back on I have to stop the engine and start it again. Unless it's extremelly cold (as in -30) the module then work and the radio kick in.
My next module will be a better one with a genuine delco chip... that or I'll modify mine... not sure yet... the problem is probably simply their regulator that don't work at low voltage...
Old 04-29-2010, 10:12 AM
InUrDreamz InUrDreamz is offline
Did the radio come with a 5-digit code? It's a security measure. so no one can steal your radio. you can program your radio to (turn off) that feature.
