Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 03-08-2010, 06:03 PM
waresjon waresjon is offline
70mm bbk throtle body
I have an 89 5.0 lx with trick flow intake and plenium with a 70mm bbk cold air intake and throtle body. My problem is a whistling noise coming from the center of the plenium. Has anybody had this problem? If so, what was your solution to fix this?
Old 03-09-2010, 09:42 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 70mm bbk throtle body
I have the 70mm BBK TB but on a 4.6L. Are you sure everything is tight and the TB gasket is in place correctly? I did have the TB screws come loose on me once after installing. Tightened them down a bit harder and no problems since.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 03-28-2010, 01:14 AM
lvdennis's Avatar
lvdennis lvdennis is offline
Check the EGR & Idle Air Control valve seals too... Best to scrap off everything and use RTV
Old 03-29-2010, 08:16 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
BBK throttle bodies are notorious for the whistling you described. Are you sure it’s coming from the center of the Plenum? Does it whistle under light throttle or heavy throttle? Also beware of the screws that hold the butterfly plate to the throttle shaft. They are also known to come lose.
My old motor did the same thing shortly hafter I installed a BBK throttle body. Eventually the throttle screw came loose and was sucked into the cylinder destroying the motor.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 03-29-2010, 01:51 PM
lvdennis's Avatar
Red Thread Locker!
