Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 03-08-2010, 06:41 PM   #1
Wags391
10-year Owner
Front end popping noise
92 S10 4x4
Whenever I'm driving, forward or reverse, I'm getting popping noises coming from the front end. It will do it when I go in reverse and stop, and when I drive forward and turn. I know the 4x4 models have sealed, non-serviceable bearing/hubs. Are these the problems and I need to replace them?
Wags391 is offline   Reply With Quote
Old 03-08-2010, 10:13 PM   #2
Schrade
Re: Front end popping noise
Originally Posted by Wags391 View Post
92 S10 4x4
If you're lucky, it's a hood bushing problem. See youtube/blazer video. I can't remember the title tho'.
Schrade is offline   Reply With Quote
Old 03-09-2010, 09:05 AM   #3
MT-2500
AF - Advisor
MT-2500's Avatar
92 S10 4x4
Inspect front end for lose or worn parts.
MT
MT-2500 is offline   Reply With Quote
Old 03-09-2010, 10:54 AM   #4
spree
92 S10 4x4
Sounds like ball joints, hub and bearing assembly will make a grinding noise and the hub goes out fast. My blazer sounded just like your does, replaced all 4 ball joints and noise went away. My hub and bearing was good 1 day and 2 days later I had to replace it for fear something was gonna fall off....hopes this helps.
spree is offline   Reply With Quote
Old 03-09-2010, 01:26 PM   #5
Wags391
10-year Owner
I should probably go ahead and do the ball joints and hub bearings at the same time, huh?
Old 03-09-2010, 04:04 PM   #6
MT-2500
AF - Advisor
MT-2500's Avatar
Only if they are bad.
Or if you have a lot of money to burn.
Could be something else to.
First.
Have a good look at things.
Let us know what you find.
MT
Old 03-09-2010, 05:38 PM   #7
Wags391
10-year Owner
First.
What should I look for in both ball joints and hub bearings to see if they are bad or good?
Old 03-09-2010, 06:12 PM   #8
MT-2500
AF - Advisor
MT-2500's Avatar
On ball joints unload pressure from joints and check movement to specs.
Hub bearings check for noise on road and any movement when moving wheel in and out.
Wheel bearing should not haveany movement or noise.
MT
Old 03-09-2010, 09:49 PM   #9
Rick Norwood
Big Tall Dumb Ass
Rick Norwood's Avatar
Go get a cold adult beverage, sit back and read this thread. It is a long one, but read it before you tear into your front end. It could save you hundreds of dollars if this is your problem.
http://www.automotiveforums.com/vbul...d.php?t=302656
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Rick Norwood is offline   Reply With Quote
Old 03-09-2010, 10:28 PM   #10
Schrade
VERY GOOD ANSWER.
See first response; #2, this thread above.
But, I think he prefers to unload the cash anyway:
edit:
Found the Y/T vid Blazer clunking fix.
Old 03-11-2010, 10:37 AM   #11
spree
I agree with MT on this one. If your hub bearings are bad you wouldn't be driving it, grinding noise would be terrible. ball joints would have movement, maybe you only need 1 or 2, but for the extra money I changed all 4 so I wouldn't have to do it again when the ones that aren't bad went bad.
Old 04-13-2010, 08:12 PM   #12
Wags391
10-year Owner
I replaced the left side ball joints and though I was good. Whacked the entire thing out of alignment right away and now I'm going to replace the other side, then an immediate alignment. Problems should go away.
Thanks.
