Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 03-08-2010, 12:32 AM
Trio3b Trio3b is offline
Send a message via AIM to Trio3b Send a message via Yahoo to Trio3b
'99 Camaro fuel gauge pegged full
Hope this is the right spot, if not let me know.
1999 3.8L coupe with gas gauge pegged. Power off gauge is off/empty. Add power and gauge pegs out "full".
I ran across a great site where someone cuts thru to access the gauge/fuel pump assembly without having to drop the axle and tank but want to check electrically first before i get into that. Fairly handy with multimeters and troubleshooting but can't find reliable schematics / wire color codes / resistance measurements.
Occasionally when warming up in the morning gauge will "wander" slowly which I thought might be a bad ground, but my understanding is that the pump and gauge share the ground so I would expect fuel pressure problems but not so. Fuel feed is good so either the float or the gauge is bad. IIRC I did visually ID what appears to be only one grnd wire.
I have determined about 300mi. per tank but still a PITA to remember all the time.
Any good tips on checking this out so I don't have to cut thru to the tank or pull out the instr. cluster which doesn't sound all that fun . . . . and now that I think about it . . . I'm SURE it won't be?
Thanks
Old 03-09-2010, 11:12 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: '99 Camaro fuel gauge pegged full
It would sound like the sending unit reference wire to the gauge is in fact grounded out.
