Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-07-2010, 08:50 PM
apeder apeder is offline
06' keypad code?
Hi, I have a 06' xlt. Any idea where I can find The factory reset keypad code?
Old 03-08-2010, 07:00 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 06' keypad code?
Do you have the owner's manual for the vehicle, and if so, did you check for a card in the owner's manual kit or a 5-digit number handwritten in the manual?
If no manual/card/hand written number, then try the locations described in the sticky at the top of the Explorer forum main page.
-Rod
Old 03-08-2010, 03:30 PM
I have the manual but no card and I cant find it written anywhere. I was also told to check the module for a sticker?
Old 03-08-2010, 09:41 PM
shorod's Avatar
SHO No Mo
Yep, the keyless entry module will have a white sticker with a 5-digit block number on it which is the master code. The sticky thread gives several suggestions on where the module is likely to be located on your 2006. I think the newest vehicle specifically discussed is a 2005, but I would suspect the location is the same in your 2006.
-Rod
Old 03-09-2010, 09:12 AM
Thank you for the great advice!
Old 05-07-2010, 06:58 AM
heerdez heerdez is offline
my 2005 has it right behind the 2nd row seat on passenger side by the whhel hub must remove the seta belt and panel there good luck
