05 2500HD steering and brake trouble
the truck has the power steering type booster
when you brake and trun sharp it has a brake pulse it has a power steering whine when you turn the wheel with it just rolling where would you start trying to fix it? |
Re: 05 2500HD steering and brake trouble
any help?
replace the power steering fluid ...for whine .. brake pulsing may indicate that the front ABS wheel sensors are messed up or those front wheel bearings are going ....usually its the driverside wheel bearing ....but why always the lft driver side ....? |
any other ideas it pulls to the right a bit when braking
power steering wine, is your belt or idler arm.
for the brakes check that side for, bad bearings or bad brake parts. now do not go cheep. the right and left side of the truck have been there since its been built. so if the right side is bad the left will be too. if you just do bearings on one side it will ware out the new parts faster. |
