Old 03-07-2010, 04:54 PM
Aocasio Aocasio is offline
Wierdness
New here, so here's my problem.
When I turn the key on my '94 3100 V6 GT the dash lights turn on, but the light on the shifter isn't on when the key gets to the run position.
Also don't hear the fuel pump.
Turning the key to 'crank', the engine turns over but does not start.
Letting the key go back to the 'run' position you hear the fuel pump for 2 seconds.
Swapping relays doesn't cure problem, all fuses are good.
I've only heard this car run once, on jack stands, when I thought the problem was the fuel pump, but I don't think that's the problem.
Any ideas?
Old 03-07-2010, 06:16 PM
Playamade Playamade is offline
Re: Wierdness
Hummm is security light on guages on? Maybe faulty ignition switch check for spark and u say fuel pump turns on for 2 seconds after u let key turn back. check for fuel in fuel rails if i remember right there is a little tirevalve looking thing on fuel rail depress it and fuel should come out. Just remember motor need compression fuel and spark to start. So i would start troubleshooting the easiest first. Take out a sparkplug or too and see if it looks wet from gas or even if it looks like its been gettin a spark
Old 03-07-2010, 08:01 PM
Re: Wierdness
Thanx for reply.
Havent tried the schrader valve,
I heard the motor once, and it sounded fine.
Afterthought... since I noticed the wierdness with the ignition position, it hasent fired with starter fluid, but I will do a definitive check for spark.
It fired with starter fluid before I heard it run.
Didn't notice a 'security' light.
Old 03-14-2010, 09:44 PM
Re: Wierdness Rolls On
New ignition switch cured the starting problem but she doesnt run right.
Acquiring an OBD II scanner tool tomorrow.
Time will tell.
Old 03-16-2010, 07:55 PM
lesterl's Avatar
lesterl lesterl is offline
Re: Wierdness
94 is OBD2? Didnt think so.
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 03-18-2010, 07:39 PM
Re: Wierdness
94 Grand Am with 3.1 V6 is supposed to take an OBD II tester.
BUt the tester didn't work, as in the car wouldn't communicate with the scanner.
Anyone have an idea?
