Old 03-07-2010, 04:16 PM
spica4038 spica4038 is offline
02 GP SE Blower problem
Blower sometimes works and sometimes not. Happens on all blower settings(1-5) and all combinations of AC/Heat/Vent settings. If I leave it turned on when not working it will eventually come on while driving. If working it never turns off while driving. Will go from working to non-working or vice versa if engine is turned off and then restarted (sometimes). During the course of this ongoing problem the radio/clock light quit working. Stereo still functions and I can see the readout if the sun hits it just right.
Recently had the battery replaced.
Have manual climate control. Any suggestions? I am not much of a DIYer and do not have much in the way of testing equipment.
Old 03-08-2010, 09:00 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 02 GP SE Blower problem
If the radio display doesn't come back on when the HVAC starts working, then they are unrelated.
Since you have no speeds at all, I would say it's a blower resistor. If you still had speed 5, I would say it could be an ignition switch/harness issue, as speed 5 gets it's power through the relay (which is built into the resistor) and is independent of ignition switch function.
On the radio display, you most likely have a burned out backlight bulb, a pretty common issue on GM factory radios.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-08-2010, 09:57 AM
Thanks for the advice. Having seen procedures for both the blower resistor and the bulb for the radio backlight these are repairs that are fairly straightforward to complete, even for a non-mechanic like me. I appreciate your quick response.
