code 1416 aux. emish. controls
my check engine light has been coming on and off every now and then for hte last yr. finally read the code and it was 1416 Manufacture control aux. emiss. contols..what is this??? maf sensor??? i noticed the light would always come on after i messed with my air filter..k*n cold air intake..
Re: code 1416 aux. emish. controls
there is a emissions vent solinoid between the cab and the truck bed. they are prone to going bad. a smoke leak detector is the best way to check it. if it is leaking it will turn the light on. check for other leaks in the evap. syatem too
u think thats it?
P1416
Port Air Circuit Malfunction/ (AIR) System Bank 2 what does this mean???? |
what yr/engine are you talking about !
Do you have air injection?
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
lucky you! you got that california air pump ....this is special just for people where you live....
this air pump fills extra oxygen into the exhaust , this passes thru check valves one on each side of the engine...this then only on cold start gives the cat conveter the needed oxygen to rapidly remove hydrocarbons for the first 5 min of the cold start.. my truck does not have this B/S pump ...but my 96 impala SS does.. you must replace these 2 check valves , then see if the problem goes away....if not replace the pump... do not replace the pump with out replacing the check valves, as these valves have rubber diaphrams that fail with this amount of useage and when they do the pump gets destroyed...I suspect your not pumping sufficent air and the O2 sensor is reporting this to the PCM/computer.. this pump should be mounted near the passenger side firewall area...remove the hoses ,,,,see water ? If yes these check valves need replacing .. you can also run engine with the hoses off and see if the exhaust blows out them ..that means there bad.. |
thanx for the info anybody else have this problem or have had to do this fix??
i see where the hoses come off the air pump but where is the thing u are talking about on the firewall?
I never said anything was mounted on the firewall..... on the passengerside of the engine bay is the air pump location ..then on each side of the engine are these check valves...did you remove the hoses and inspect, troubleshoot as I recommended...? do you have a manual ? any Idea what I'm describing ? |
on each side of the engine off the metal tube that comes off the air pump i saw a big looking nut thing that look like it could have something inside of it..is this where the check valve is located?? what if i just left the valves out of it??
if you have time and money you should purchase repair manuals and start studing on how these all work... go to the part store and see what these parts look like ...if you have tools and the ability to properly use them this is an easy task.. if not go to a repair shop .. |
I dont know about silverados but i have had trailblazers with the same code and since they are mounted on the frame they suck up water and grenade. I would check the pump first then move down the lines.
these valves are only good for 10yrs and should be checked ever year for back pressure/water entering the pump....on the LT1 the air supply for pump is just in front of the MAF so the MAF also gets dirty ...as the exhaust gas goes into the intake which also throws other DTC'S... I had to buy ac delco check valves because the aftermarket check valves by standard are only 5/8 inch dia..the OEM are 7/8 dia ..so the hoses did not fit correctly on the stardard manufacturers part.. with the pump it was 200.00 total...to fix.... |
| The Following User Says Thank You to j cAT For This Useful Post: | ||
010175 (05-23-2013)
