Old 03-07-2010, 11:11 AM
alekake alekake is offline
96 cherokee distributor replacement
My 6 cyl 96 grand cherokee is sqeeking from the distributor shaft.
How do i repair/replace the distributor?
Old 03-07-2010, 12:04 PM
jdl jdl is offline
Re: 96 cherokee distributor replacement
I can give you the removal procedure,but, you need to be sure that is the problem.
Old 03-07-2010, 01:47 PM
Thanks jdl
I'm pretty sure the shaft bushings are bad. I can push on the distributor and cause it to squeek less. Is it best to replace the entire distributor or will i be able to easily purchase and replace the bushings only. Any advice is appreciated.
Old 03-07-2010, 02:45 PM
jdl jdl is offline
Is the hold down mechanism tight? I've never seen dist. bearings or bushings in a partsbook.
Old 03-07-2010, 04:07 PM
Yes it is tight, i saw replacement bushings on line but i think they must be for pro rebuilders.
I just replaced the cap and rotor button. No improvement. A remanufactured dist. is $75.00. I think that might be what i'll do. How do i insure the gears will align properly when i install the new one? Is it the direction of the roter button on the new one that i should match up with the old one? It doesen't seem to tough to remove and replace but i don't want to screw something up!
