Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-13-2003, 04:17 PM
york2600 york2600 is offline
Send a message via AIM to york2600
Caste nuts on ball joint just spins
I'm trying to pull the axels out so I got out the trusty old Helm's and started working. I needed to remove the lower ball joint, but first I had to remove the lower castle nut on the suspension. Well it's obviously really really tight so I used a pipe and got it loose. The problem is now it just spins. WTF? Am I missing something here? Is there any way to get this thing off now without cutting it off. I really need to get the Axels out so I can get by B18c1 out and get crackin with this project.
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Old 04-14-2003, 06:18 AM
hondacivic4drlx's Avatar
hondacivic4drlx hondacivic4drlx is offline
Send a message via AIM to hondacivic4drlx
hold bolt with pliars, then unbolt nut with wrench
Old 04-16-2003, 07:36 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
or wedge the ball joint seperator in and put tension on it.
Old 04-17-2003, 06:36 AM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
ditto
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
