Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 03-06-2010, 08:07 PM
jeff patten jeff patten is offline
Help
I put a fuel pump on my 94 getting fuel and spark but wont start
Old 03-06-2010, 08:17 PM
jdl jdl is offline
Re: Help
Use a fuel pressure gage. What is the spec? A couple of thoughts, without rpm signal, no injector pulse. Use a noid lite on injector plug, see if it pulses, engine cranking? There may be a problem with the spider fuel system, where applicable. Any codes?
Old 03-06-2010, 08:30 PM
more help
I guess I should have said more first time here it is cranking just wont fire need to get fuel pres. gage
Old 03-06-2010, 09:06 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: more help
Here's where you check it.
You can also take the rubber air duct off the intake/throttle plate, open the throttle, spray a some carburetor cleaner into the intake then try to start the engine.
Old 03-06-2010, 11:37 PM
94 ecu
has anyone heard of a ecu problem after a fuel pump change if so what can I do to reset it
Old 03-07-2010, 06:43 PM
AF - Advisor
Re: 94 ecu
Unplugging the battery generally resets everything.
What's the problem?
Old 03-07-2010, 06:48 PM
Re: 94 ecu
it has fule and spark but wont start
Old 03-07-2010, 06:51 PM
re ecu
it has spark and fuel but wont start going to get a preshure guage on Mon
