ABS, Trac Off, Check tire press lights stuck on
I drive a 97 GT, for a while now (a few years) my ABS, Trac Off, and Check tire pressure lights on my dash are lit up, I believe it is a sensor of some kind that needs to be replaced but im not sure. Everything seems to work fine as far as my abs and trac control, but the lights being on all the time is annoying. Anyone know what sensor this may be or what I can do to fix it? Thanks.
Re: ABS, Trac Off, Check tire press lights stuck on
How many miles do you have?
Each wheel has a hub assembly. Within the hub is the ABS wheel sensor. Most likely a bad hub assembly but technically it should be scanned with an ABS capable scanner/scan tool just to be sure. Also, check the wiring and electrical connectors at each hub. The ABS, traction control and tire pressure monitor on 1997 models all reference the same wheel sensor for operation.
Yeah it has 131,000 on it so im sure its exactly what you suggested, ill look into it. Thanks!
