Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-05-2010, 07:23 PM
mikey531 mikey531 is offline
Send a message via Yahoo to mikey531
I am getting very frustrated with this
I have a 1997 Grand Cherokee limited. I cannot get the dome light to come on when I open the door or with the dash switch. I have replaced the bulb and then checked the bulb and it works. I then tried another one that I checked and it doesn't work. Both reading/map lights in the dome light work. I have a red, yellow, and black wire going into a plug. I have power to the red and yellow. I assume the black is ground. Both lights in the front doors work with the switch and when I open the door, but no dome light ! I have pulled the fuse marked CTSY LMP in the fuse panel in the kick panel. The lights in the doors did not go out, but the read/map lights did. Is there a separate fuse for the dome light???? What in *^#& am I missing??? Can someone please help me?
Thanks !
Old 03-06-2010, 12:54 AM
hundahunta hundahunta is offline
Re: I am getting very frustrated with this
do you have a bk, pink and yellow, wire at the dome lamp assembly?
Old 03-06-2010, 04:44 AM
Yes, I have power to the yellow and the red/pink wire.
Old 03-10-2010, 09:56 AM
dornier34's Avatar
dornier34 dornier34 is offline
Send a message via Yahoo to dornier34
Thumbs up Re: I am getting very frustrated with this
Thanks !
Hi there OK here is some tips for you this truck has 2 door module system passenger and rive module ,each module stand alone module and communicate on the ccd bus system, the fallowing list provider supported by the door module system: 1 power door locking and unlocking 2, power window, 3 key off usage for 30 seconds,4 rolling lock activation, 5 heated exterior mirror ,6 driver and passenger side courtesy lamp illumination, check if this module are working properly be shorted , its easy to take out and disassembly, lubricated and out back together, check the door locks lubricated and make sure are working properly lock and unlock using the keyless, spray with some lubricants in the door lock ,check the switch each door maybe is making some switch let me know thr results dornier34
Old 03-12-2010, 10:54 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
OK so you have power to the wires @ the dome light. Check the ground and the dome unit itself; I've seen dome lights have corrosion in them (mostly on really old cars) or have something like a wire connection broken inside.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-12-2010, 11:24 AM
Thanks for the help. I think I figured it out, there has to be a break in circuitry going to the dome light. I am looking for one from a junk yard now.
Thanks Again!
Old 03-12-2010, 11:25 AM
Sure thing...let us know if the "new" part doesn't fix it!
Old 03-15-2010, 09:16 PM
Before I could get that jeep fixed I have a new problem now with my other Jeep. see this:
http://www.automotiveforums.com/vbul...d.php?t=980512
Old 03-16-2010, 11:27 AM
dornier34's Avatar
Hi there, ok there 2 things you can do to fix this problems , #1 you can take the relay out and disable the key less system ,or #2 you can only disconnect the wire positive or negative that go to the horn and disable the horn and eliminate the noise and leave just working the door locks, good luck
