Old 03-05-2010, 01:14 PM
Prof_h Prof_h is offline
Stalling and electrical components reset
Hi,
Recently I've noticed my car just stalls and all the electrical components reset. What gives? Anyone have this happen? I just replaced my fuel filter, thinking that needed changing, but the stalling happened again. It doesn't do it very often, but it sure is weird.
I also had the car SE light indicate that the Crank Shaft Position sensor was sending a code. The car runs fine, shifts a little rough into 4th sometimes, but everything seems okay, fluid levels are fine and I just had the tran. fluid changed. Any ideas?
97 PA 3.8 V6 140k miles
Old 03-05-2010, 04:24 PM
C man C man is offline
Re: Stalling and electrical components reset
Reset as in you have to reprogram the radio time etc.. or as in the car shuts of and comes back on?
95' PARK AVENUE 168,000 MILES
Warning : Listen at your own discretion
Old 03-05-2010, 08:47 PM
Jrs3800 Jrs3800 is offline
Originally Posted by Prof_h View Post
Hi,
Sounds a lot like a ground issue with the electrical system.. Check all of the grounds you can find, start under the hood...
