Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-05-2010, 12:03 PM
W-T-Katt W-T-Katt is offline
1999 Bonneville SLE, front suspension??
Hi all, a few days ago, I noticed a humming coming from my 1999 Bonneville SLE while going down the highway, best way I can think of to describe it is noisy (aggressive tread) tires. I've had the same tires for about a year now. The "hum" would rise and fall with speed. Aside from that everything appeared fine, no pulling, etc. Then, last night I started to get an almost grinding noise with loud clunks while traveling (any speed). Still no pulling but it feels as if something is about to break. I parked the car and had my son turn the wheel back and forth a little and something on the passenger side appeared to be sticking, grabbing, making a little clunk noise. I couldn't identify just where it was coming from. Does anyone have any experience with this scenario?
Thanks,
~Bill
Update, I just jacked it up and did the 12-6, 9-3 test with trying to wiggle the tire. I got nothing on the side to side but had definite play on the up and down. I forget what that means though (ball joint, tie rod, wheel bearing?). Anyone?
UPDATE: OK, after having a friend come over and wiggle the tire while I got under to look at what's happening, I could see that it was most definitely the wheel bearing. ;-)
Old 03-05-2010, 08:33 PM
Jrs3800 Jrs3800 is offline
Re: 1999 Bonneville SLE, front suspension??
Yeah wheel bearings are a common occurrence on these cars... I have replaced both the front hubs on my 95 Bonneville 2 times..LOL..
Old 03-16-2010, 01:33 PM
l67cooled l67cooled is offline
Thanks,
~Bill
12 and 6 shake is wheel bearing. 3 and 9 are tie rods. Ball joints would be tested by having wheel off the ground, use a pry bar and pry the tire up; if there's any movement ball joints are worn.
Old 03-16-2010, 04:46 PM
Ty ;-)
