Old 03-05-2010, 10:02 AM
kboaz2001 kboaz2001 is offline
Blower Switch
Our 2003 Grand Prix blower switch only works on #3 and above. Is this a blower switch resistor problem?
Old 03-05-2010, 10:51 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Blower Switch
Very possible.
The #2 fan speed resistor is probably burned out. The #1 fan speed uses all the resistors in series. If #2 is open #2 and #1 will not work. #3 and higher do not use the lower speeds resistors so they continue to work.
Old 03-05-2010, 11:04 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Blower Switch
most likely yes. there are other things that can cause this, but the resistor is the most likely cause.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-05-2010, 06:39 PM
Paulk501 Paulk501 is offline
Re: Blower Switch
i have an issue on my 1997 pontiac grand prix gt blower switch. the blower only works on number 5, i have replaced the resistor, and the switch all fuses are good. the blower motor is fine. also when it is set to speeds 1-4 the headlights will go out and the rear defroster will not function. i have read that the ignition switch may be the culprit.
anyone have any input on this?
Old 03-06-2010, 01:12 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Blower Switch
You have a bad ignition switch.
Timeslip 08/12/06
AF Community Guidelines
Old 03-06-2010, 05:29 AM
Re: Blower Switch
Everything else works in the car, so I am hoping it is just the blower resistor, I would hate to change an ignition switch! Thanks.
Old 03-06-2010, 08:59 AM
BNaylor's Avatar
Re: Blower Switch
Why? Not easy but not difficult either. See link below.
Click here
Timeslip 08/12/06
Old 03-06-2010, 11:04 AM
richtazz's Avatar
Re: Blower Switch
Paulk501,
I agree with Bob (Bnaylor) that you have a bad ignition switch.
kboaz2001,
If you have no other symptoms, the resistor should fix your issue.
Old 03-06-2010, 08:54 PM
Re: Blower Switch
thanks guys, ill be ordering one soon
Old 03-10-2010, 08:35 AM
Re: Blower Switch
Originally Posted by richtazz View Post
Paulk501,
i got my ignition switch! 3 hours and $100 later everything works again!!!
THANK YOU!!!
