Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-04-2010, 06:00 PM
Kyle Wymer Kyle Wymer is offline
airbag code
My sport trac is flashing a code 4-3 have not found this code in any web page and hoped someone here would reconize that code. The light stays on after it flashes the code. This is really anoying to me plz help thank you
Old 03-04-2010, 09:20 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: airbag code
Welcome to the forum!
What year is your Sport Trac? Lamp Fault Code (LFC) 43 probably means "Restraint System — Impact Sensor Status (Driver Side Impact Sensor Circuit Failure)" but knowing the model year would help confirm this.
-Rod
Old 03-04-2010, 10:12 PM
Re: airbag code
2004 gen 1
Old 03-05-2010, 06:46 AM
shorod's Avatar
SHO No Mo
Re: airbag code
For 2004 the code definition changed to "Restraint System — Impact Sensor Status (Driver Side Front Row Impact Sensor Circuit Failure)".
-Rod
Old 03-05-2010, 07:48 AM
Re: airbag code
thanks but this morning the airbag light flased a code 4-2 is there multiple problems and do you know how to fix these problems thanks again
Old 03-05-2010, 12:55 PM
shorod's Avatar
SHO No Mo
Re: airbag code
I'd suspect that one of these mornings you miscounted, or this is an elaborate plan to get me to post all the SRS codes, one at a time.
LFC 42 is "Restraint System — Impact Sensor Status (Front Impact Severity Sensor Circuit Failure)". I'd start by making sure the sensor has a good, clean ground to the chassis.
-Rod
