Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-04-2010, 02:36 PM
2old2care 2old2care is offline
87 Camry Alltrac Suspension
My Mechanic says I need a new bushing for lower control arm (rear) Toyota dealer says you must buy the whole piece because bushing is not offered separately. Does anyone know if these are offered as aftermarket parts?
I just dropped a ton of money replacing the struts (sometimes wish I didn't own an alltrac). Runs strong @ 188,800 miles but drives like junkright now.
Any suggestions/info would be greatly appreciated!
Old 03-04-2010, 03:52 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: 87 Camry Alltrac Suspension
I had to bite the bullet and replace one of the rear lateral control rods on my 94 Camry using the Toyota OEM part. There was no aftermarket part available. I think I paid $156 for one about 2 years ago. If you do find one, post back here and let everyone know about it.
Thanks and good luck.
Mike
Old 03-08-2010, 09:24 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I have not seen any replacement bushings for the Camry control arms either. Your control arm is actually two-piece (frt/rear), so you might be able to replace just the arm part you need, but they seem to run $50-75 depending on which part it is and if you need the ball joint as well.
Wow, did another search...I've found one of them available separately but don't know if it is the one you need:
http://www.partsgeek.com/catalog/198...m_bushing.html
The same place has bushing kits for the 1986 model year, but don't know if that is compatible with the '87. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
