Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 03-04-2010, 10:26 AM
ottomatic ottomatic is offline
1997 dodge stratus 2.4 no start misfire on 2 & 3
I have a 1997 dodge startus 2.4 , There is no injector pulse or spark on cylinders 2 & 3 . 1 & 4 are fine. I have replaced the crankshaft position sensor, camshaft position sensor & the coil. ignition coil number 1 is getting proper signal from the ecm, but the ignition coil number 2 is lacking signal, the dark blue/dark green wire ohms out properly from the ecm to the coil. Im assuming the asd relay is working because 2 of the cylinders are firing correct. Im lost
Old 03-04-2010, 10:56 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 1997 dodge stratus 2.4 no start misfire on 2 & 3
Did you check for signal with the coil plugged in or unplugged?
Old 03-04-2010, 11:34 AM
I checked signal with coil plugged in.
Old 03-04-2010, 12:39 PM
I am leaning towards the ecm being bad, seeing as how there is no signal for that coil coming from the ecm. But I could be wrong.
Old 03-05-2010, 05:09 PM
It ended up being the ecm. No signal to coil
