Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 03-03-2010, 11:18 PM
yukondan yukondan is offline
Smile Pinion seal replacement
Does 1967 Chevy rear end have a crush pinion sleeve and if so should it be replaced when the pinion seal is replaced.
Old 03-16-2010, 09:34 AM
j cAT j cAT is offline
Re: Pinion seal replacement
if the pinion seal is leaking you simply replace the seal ...hopefully thats it ...you just remove drive shaft and with a tool pop out the seal ..install new use a socket on the circumference and push on ..
its been a long time that I did this job on a 1967 ...
Old 03-17-2010, 01:36 PM
maxwedge maxwedge is offline
A990 racer
If there is a crush collar it should be replaced and the pinion preload reset, if it has shims just tighten to about 200 lb/ft . Not sure but I believe it has shims.
