Old 03-03-2010, 10:32 PM
Native3000gt Native3000gt is offline
Positive Battery cable
got a new one.. my Postive battery wire is kinda loose or not working or just bad. where could i find a new one and how would i get it replaced. could i get some step by step guides. thanks a lot.
Old 03-04-2010, 03:52 PM
91STT 91STT is offline
3SNJ Pres
Re: Positive Battery cable
you can pick up the battery cable from most auto parts stores, pep boys, rockauto, advanced, etc.
to replace it depends if you have a SOHC or DOHC.
for the most part, it is very similar for either engine.
DOHC only has 2 connections, 1 to the fuse box & the other to the starter.
SOHC has 4, 2 to the alternator, 1 to fuse box & 1 to starter.
the way you install it is the reverse of the way you remove it.
1991 Stealth R/T TT
It looks stock, so it must be.
Old 03-04-2010, 06:56 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Its been awhile since I've been under the hood of my car but I am 99.99999999% sure I have two wires for the positive cable. One small gauge to the alt fusible link in the fuse box and one to the starter. Other than that I have one going for my amp. I would remember two more if they were there. And yes my car is a SOHC.
Old 03-05-2010, 01:07 PM
3SNJ Pres
stealthee is right, i misread the diagram, there are 2 coming off the battery. a white to the fuse box and black-red to starter.
1991 Stealth R/T TT
