Old 03-03-2010, 07:56 PM
Exploit1086 Exploit1086 is offline
2002 Grand Am GT Turn Signels
I am having a problem with my turn signels. They cut out at random when i'm using them. All bulbs are fine. The next thing I want to try and replace is the flasher fuse, however I cannot seem to find it. Can someone help me please?
Old 03-04-2010, 09:41 AM
andretti andretti is offline
Re: 2002 Grand Am GT Turn Signels
Very common problem, flasher is built into the hazard switch.
Old 04-19-2010, 10:10 PM
trch trch is offline
Check online to see if yours is one with a recall. Alot of them had a recall for this. My nephew has a 2001 and his did. It will cover the part and labor to be fixed.
Old 04-19-2010, 11:03 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Replacing the fuse is totally useless since the problem is intermittent. The fuse can't be bad or blown.
It's either a bad contact in turn signal switch or in hazard switch. When problem happens, try to pull the turn signal switch against you a little bit (w/o activating the high beam) to see if it works. I had this problem with my Oldsmobile.
And test the hazard switch to see if it's not that the problem. If the 4 flashe, the problem is not the hazard switch, but the turn signal. Or a bad relay, but it's rare.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 05-01-2010, 09:50 AM
kizzle kizzle is offline
Same thing happened with mine. the turn signals are on the same switch as the hazard lights and TCS switch. if you push down on the hazard light button, not push it in, but actually push it down, they will start to work. i took mine for the recall, but the previous owner already did, its just going out again. annoying, yes. Money to fix it myself... well idk cause idk how much it is.
