I have a 98 Sonata. Bought used, never used the alarm. Last night I parked the car and when I came back to it the alarm went off when I opened the doors. The ACC worsk but the car will not start.
The Key FOB lights up, but it does not work on the car. Someone please help me out. 98 Sonata. Thanks in advance.
94 Caprice 9C1, 84 CUCV Blazer, 07 TL, 96 F250 PSD. Last edited by ncinirator; 03-04-2010 at 01:22 AM. |
After digging around the fuse box I discovered the valet switch tucked above the fuse box. I switched it to the down position with the battery disconnected. I reconnected the battery and the alarm sounded for a few moments then stopped. Problem solved. The location for the valet switch on the 98 Sonata is in the fuse box compartment, just above the actual fuse box. Depending on your size, you'll really have to contort yourself under the dash/steering wheel to see the switch. Hope this helps.
94 Caprice 9C1, 84 CUCV Blazer, 07 TL, 96 F250 PSD. |
Re: Alarm help
I have a 99 GLS sonata that I also bought used. I always thought that alarm was an aftermarket system.
If I open the door and set off the alarm I have to turn the ignition over to the ACC position then reach down to the floor board kick plate by my left foot and press a reset button to reset the alarm and allow me to start the car. Is that the "valet" switch your talking about? Or is there another switch that will do something different? |
Re: Alarm help
