Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 03-02-2010, 01:30 PM
thakoolkid thakoolkid is offline
need help question about my transmission !!! its slipping
OK well my transmission starting slipping the other day, it does work but i have to speed up slow. If i just press on the gas right away it wont accelerate i have to start little by little, and when its running if i let go of the gas I have to start from 0 again little by little. What could it be ? can it be repaired ? OR DO I NEED A NEW TRANSMISSION ? they are quite expensive !
Old 03-05-2010, 09:00 PM
WILLIE1226 WILLIE1226 is offline
Re: need help question about my transmission !!! its slipping
I have the same problem. Mine has 166K and it's a 98. I had my mechanic add some transmission conditioner and that helped for about 2 weeks. I'm going to take it to the dealership and see if it can be flushed properly or something. Supposedly the filter is nonserviceable!
Old 03-07-2010, 03:12 AM
man THAT sucks asssss someone help we need help !!!!! economy is too bad to be paying 1 grand for transmissions
Old 05-30-2010, 10:09 AM
-kasim- -kasim- is offline
I had a problem with my transmission, it was slipping on each gear and a friend of mine told me to change the (TPS) Throttle Position Sensor that is located on the opposite side from the throttle pulley.The problem was resolved and,I did change the transmission huile with filter it helps alot ..
Old 05-31-2010, 10:52 AM
badbrakes badbrakes is offline
Hey Kasim.
Thanks for posting. Interesting fix and good for you... a TPS is a 'little' more affordable than tranny. How did you troubleshoot this though ??? Did it throw a computer code (either the tranny or TPS) ?
Merci,
Old 05-31-2010, 04:16 PM
My friend is a garage owner, and he scanned my van with his snap-on scanner and found out that the prob was the TPS..
Old 08-04-2010, 12:32 AM
vids1386 vids1386 is offline
This kind of problem,regular servicing of the transmission every 25,000 miles,
including changing the fluid and internal filter needed & also we have to regularly check the fluid levels.
Old 11-16-2010, 10:10 PM
Ez Dino's Avatar
Ez Dino Ez Dino is offline
The specialist
Send a message via AIM to Ez Dino
you cannot change a odyssey filter with out not removing the transmission it is inside the transmission.
