Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 03-02-2010, 12:06 PM
debjeff4948 debjeff4948 is offline
2007 Corolla Inside Roof Carpet
Is it normal for the inside roof carpeting to look like shag carpeting. My son is tall and has bushy hair. I guess it is his hair that is causing this problem. How can this be repaired?
Old 03-05-2010, 02:02 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 2007 Corolla Inside Roof Carpet
The shag or fuzzy look is not normal and yes probably due to the headliner commiserating with your son's hair. Pulling at the lumps may reduce the shag look but it will cause more material to be pulled from the weave, making it still appear fuzzy. However, if you are good with scissors then you can clip the fuzzies close to the roof to reduce the fuzzy look. I might recommend a good electric hair clipper, but you'll have to be very careful to not poke the headliner with the shearing head.
If worse comes to worst, the headliner can be recovered with new fabric. A fair job to install, the worst part having to remove the headliner.
In the meantime, he can wear a hat...or a hairnet. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
