Old 03-02-2010, 02:03 AM
pithi69 pithi69 is offline
Upgrading Injectors
Hey 90 Civic B18B1 swap, i've upgraded fuel pump to walbro. I was wondering if there is a point to upgrade my injectors even though the motor is stock besides a few bolt ons. If so, what are the highest CC injectors I can use? I also want to upgrade my fuel rail and so forth in the future...
Old 06-01-2010, 09:04 PM
1992 honda monster 1992 honda monster is offline
Re: Upgrading Injectors
Well the more air and fuel you have, the more power you will have. But the amount of power your wanting isn't going to come from the injectors. If your going to turbo the engine, the it's an good idea but other than that it's only going to give you a 10hp jump. Go with 330 cc. If you want more power and you get bigger injectors, get a better throttle body. You have a 56mm throttle body, Go with a 70mm and with your 330cc injectors you should have around 30hp-45hp jump. That is if you have a intake.
Old 06-08-2010, 07:09 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
i think it's pointless to do all these fuel upgrades since your car doesn't require any more than stock flow.
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 06-09-2010, 07:42 PM
Laner123 Laner123 is offline
Wouldn't the car run to rich then?
Old 06-09-2010, 08:31 PM
BLU CIVIC's Avatar
調整器
not with just an upgraded fuel pump. the stock fuel pressure regulator will keep it in the green
The name's Adrian
2011 CR-Z - Stock
