Old 03-01-2010, 09:16 PM
l-man l-man is offline
2007 Yukon Xl
Hi everyone, I just got a 2007 Yukon xl with 52k mi. I was wondering if I should add a transmission oil cooler to "help extend the life" of the transmission, or should I leave well enough alone. Also, what is the deal with the throttle body spacers, are they worth the money? Kinda seems to easy to do any good.
Old 03-02-2010, 10:04 AM
maxwedge maxwedge is offline
A990 racer
Re: 2007 Yukon Xl
If you live in a hot area of the country or pull a trailer the cooler is a good idea. The spacer is not going to do anything for a daily driver.
Old 03-02-2010, 12:34 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 2007 Yukon XL add tranny cooler?
I would also add a tranny cooler if you use it to tow trailers or do frequent trips up into the mountains, or both. Even for long, highway trips, dropping the temp at least 10° below what comes out of the radiator will help alot. For a tranny, cooler is better...except maybe Alaska.
I concur with the TB spacer...pretty useless on a stock engine.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 03-03-2010, 08:39 PM
Re: 2007 Yukon Xl
Thanks for the advice, I wasn't sure if you could get a transmission "to cool", I am moving to Florida soon, so I think I am going to get one, I saw a plate/fin design from Hayden that looked decent http://www.summitracing.com/parts/HDA-679/ Is this something a do-it-yourselfer can do at home with common tools? About the most diffucult thing I have done is replace a rear break rotor on a 2001 Foed Explorer. (which was pretty easy)
Old 03-03-2010, 08:41 PM
Re: 2007 Yukon Xl
Was also going to ask about engine oil coolers???
Old 03-04-2010, 10:04 AM
jdmccright's Avatar
The RustBuster
Re: 2007 Yukon Xl
Typical tranny fluid temps run from 190-230°. The tranny is designed to work with hot fluid, so cooling too much may make it feel sluggish. However, the fluid starts to break down and oxidize around 195°, limiting it's lifespan to the typical 30k-50k change intervals. I don't have the reference, but it is said that tranny fluids have a life span of 100k miles if kept at 175°, and every 20° increase cuts that lifespan in half. So, ideally a drop of at least 20-40° would be very advantageous. A good temp range to shoot for is 140-180°.
In a stock system, the transmission fluid lines run through a heat exchanger inside the radiator to help warm it up when it is cold and keep it from getting too hot...the coolant is kept at around 195-200° with the stock thermostat. So, cooling is limited to the radiator temp.
If your truck has a "heavy duty trailering" option package, you might have an external transmission fluid cooler already mounted behind the grille in front of the A/C condenser and radiator...approximately the size of the unit you're looking at buying. If the RPO sticker in your glovebox has the code "KNP" you already have an auxiliary tranny cooler. If so, you can stilll add a second cooler, which is easier to do, or add a thermostatically controlled auxiliary fan mounted directly to your aux cooler. The fan is a little more expensive option, but the advantage is that cooling is more direct and not as dependent on vehicle speed. Here's a small one that would fit the factory installed aux cooler:
http://www.summitracing.com/parts/DER-16507/?rtype=10
If you're not up to cutting and splicing wires, the second cooler will probably be easier. Finally, a trans fluid temp gauge is also a good idea if you want to keep an eye on it while trailering.
[EDIT] I've also read that even with the factory tow package option, temps can still creep pretty high when trailering. A second aux cooler is the cheapest and easiest route to help keep temps down.
Probably too much info, but I hope this helps you decide...goood luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 03-04-2010, 11:59 AM
Re: 2007 Yukon Xl
That was great information, in my opinion there is no such thing as to much information. I am going to have to look and see about the factory cooler, I havn't had the chance yet. Thanks for the great advice.
