Old 03-01-2010, 08:40 PM
92.H.A.ex 92.H.A.ex is offline
Angry over heating
onlly overheating when sittin at a light.........not when driving......just replaced thethomastat and senser...........fan only come on when car is off? and dont caome on when ac is on.......AC blow cold...but the heater dont work?...........waterpump?..wats the best coolant to use in a honda.....50/50?
Old 03-02-2010, 02:04 PM
somick's Avatar
somick somick is offline
Re: over heating
Did you bleed the system?
How about coolant level?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 03-06-2010, 09:16 PM
Re: over heating
nope hoe to do that?
Old 03-07-2010, 09:08 PM
somick's Avatar
Re: over heating
There is a bleeder screw on top of the thermostat housing. Twelve millimeters wrench will do it. Unscrew it couple of turns until you see a steady stream of coolant without bubbles.
Close the bleeder screw.
Run engine with the radiator cap off and wait for the radiator fan to come on. Honda recommends the fan should come on two times. I have never been able to get it. I consider one time is enough.
Turn the engine off. Top off fluid.
Make a test run. Check the coolant level in the expansion tank and add coolant as necessary.
In bad cases, when you have problems with bleeding the system you may park on an incline nose up, open the radiator cap and just run the engine. Air may escape through the open radiator neck.
I hope this will help.
Good luck,
Sam
Old 03-12-2010, 07:23 PM
FrankVtec88 FrankVtec88 is offline
Re: over heating
What is your def of overheat? Do you consider slightly above halfway is overheat? Or is it reaching more than 3/4 way to the top?
