Old 03-01-2010, 05:36 PM
cjsbosox's Avatar
cjsbosox cjsbosox is offline
How can I replicate suede?
Any how-to on this? Tips? It would be much appreciated.
Thank you
Old 03-01-2010, 06:39 PM
CFarias's Avatar
CFarias CFarias is offline
Re: How can I replicate suede?
What I do works real well, but tends to hide details in the plastic. I cover the part in embossing powder. Then I spray on some relatively thick coats of the paint I'm using to simulate the color of the suede. A very light dusting of semi-gloss to give it a some sheen and your done. Practice this first before you try it on the model part.
Old 03-01-2010, 06:55 PM
cjsbosox's Avatar
Pic?
Old 03-01-2010, 11:34 PM
countach79's Avatar
countach79 countach79 is offline
Hey
I use a spay called make it suede by a company called krylon
im pretty sure you have it in the USA
i just spray it on then spray my new colour over it
if i want i bright colour like in the pic i will spray white primer then the new colour
Old 03-02-2010, 05:55 AM
CFarias's Avatar
Originally Posted by cjsbosox View Post
Pic?
Sorry, I don't have a pic.
Old 03-02-2010, 11:18 PM
robertgreen94's Avatar
robertgreen94 robertgreen94 is offline
The krylon "suede" works really well, just make sure you keep the item away from the can. It can go down heavy but drys very different. Use a scrap piece of plastic to try it out. I have been told you can use flour through a fine mesh.
Old 03-02-2010, 11:33 PM
Wolf95 Wolf95 is offline
how would you stick the "embossing powder" or flour to the surface? elmers glue?
Old 03-03-2010, 07:31 AM
CFarias's Avatar
Yes, diluted Elmers (white) glue is what I use. I coat the part with it, let it set up a bit to get tacky, then completely immerse the part into the embossing powder. After a few minutes have passed, I remove the part and gently blow off any excess.
At this point the embossing powder look very convincing if you were simulating carpet, but after a few coats of paint it will look more like suede.
Old 03-03-2010, 09:45 AM
where could I get embossing powder? I still can't find flocking either... >_<
Old 03-03-2010, 12:10 PM
racer917's Avatar
racer917 racer917 is offline
I have used fluor/baking soda. As for making it stick I, no Elmers required. I simply paint the part the correct color and use that to stick the powder. After a few minutes dust off the excess, re-spray. May have to repeat 2-4 times but this can only take a few minutes. Looks good.
Old 03-03-2010, 03:26 PM
interesting concept... I should try this out sometime..
Old 03-03-2010, 05:04 PM
cjsbosox's Avatar
Ay regular hobby store like Michael's or Hobby Lobby should have it. I found some there but figured I could use powder instead.
Old 03-03-2010, 08:08 PM
CFarias's Avatar
As mentioned above the embossing powder can be found at the large hobby chain stores like Hobby Lobby or Michaels. It will be where the stamp making and scrap booking items will be. They usually sell it in small plastic jars.
Interesting idea about the flour/baking soda. I'll give it a try.
