Old 03-01-2010, 02:23 PM
cramer_77 cramer_77 is offline
93 K1500 5.7 running rough
Got a truck at work that has got some problems. Heres the run down, we replaced the engine approx. 19k ago(customer ran it low on oil), replaced distributor and spark plugs approx. 10k ago, replaced cap and rotor 7k ago. Replaced distributor again 5k ago. This time in the shop we have replaced the pickup coil(out of specs), distributor cap, rotor, wires, plugs, both coolant sensors. Whats happening is truck will run extremely rough when cold, then about the time it gets warm truck will smooth right out and run like a champ. Truck ran fine after we replaced all the ignition stuff until it got up to temp, then it wanted to keep dieing. Now, its exactly opposite, runs bad cold, smooths out warm. Didn't know if anyone has ran into this before or might know somewhere to look. Took truck on a drive, got about 1/2 mile down the road and it starts bucking and running bad so i pulled over into a parking lot. Sitting there idling it kept acting like it wanted to die, and the scanner was reading no rpms. Drove it back to the shop, was never able to get above 3rd gear, and it died twice trying to get it back into the shop. Thanks in advance.
01 Silverado 2500HD, HID lows and highs, cold air kit, leveling kit, brush guard, dual flowmaster outlaw mufflers, 5% windows.
Old 03-02-2010, 08:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 93 K1500 5.7 running rough
Any engine codes?
Good hot blue spark to all plugs?
How is the fuel pressure doing?
MT
Old 03-02-2010, 10:00 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I don't see you checking or replacing the ignition coil. Those usually just up and die, but some do get temperamental before they let go...rough running, missing, or giving off "cold" sparks. Might try a new one. Double check your grounds and other wires, too. When the truck engine is hot it may be expanding enough to make contact with a critical ground wire or sensor.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 03-02-2010, 05:56 PM
No codes have been set, I checked fuel pressure it was within specs, didn't check the color of the spark(have to do that tomorrow when i get back to work) i did the bench test for the coil and it checks out ok, although, it does look like its possibly the original coil, 200k on the truck all together. My boss talked to a mechanic friend of his today and he is supposed to come by and do a "ground sweep" never even heard of it.
Old 03-05-2010, 05:36 PM
just thought i would update some people on this, after having another mechanic friend stop by the shop for a couple of hours, found the distributor at fault. Replaced the distributor and truck runs like a champ. Sad part is that if my boss had listened to me then the truck wouldn't have been in the shop nearly as long.
Old 03-06-2010, 08:55 AM
MT-2500's Avatar
AF - Advisor
Thanks for posting back how it went and the fix.
But was wondering how you found the problem?
WAS THE DIST SHAFT BUSHING BAD?
What test was done or how did you find the dist problem?
Thanks
MT
Old 03-13-2010, 05:04 PM
samstone samstone is offline
I was having the same problem. I noticed that the spark advance under the distributer cap was hard to move. I shot it with wd 40 and then shot some lube in, kept moving it until it was easy and my truck runs like a champ. I got lucky on this one.
