Old 03-01-2010, 02:27 PM
tjensen tjensen is offline
98 taurus died on road
98 Taurus died on the road. Had it towed to house to check out next day. Don't know if it is a fuel pump problem or pressure regulator. Tested the pressure on line and it only read around 15. Keep turning key switch to finally get correct pressure on line. Does anyone know if this is a sure bet on replacing fuel pump or should I look at something else before making final decision?
Old 03-01-2010, 03:16 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 98 taurus died on road
Welcome to the forum!
You could check/replace the fuel filter first, but the symptoms you describe, assuming the fuel pump was receiving power each cycle of the key, suggest a weak fuel pump.
-Rod
Old 03-01-2010, 03:37 PM
Thanks Rod. Appreciate the advise.
Old 03-02-2010, 02:58 PM
Willyum Willyum is offline
Jens,
If you read my exchanges 3 spaces down you'll see I recently went thru a similar situation. My wife and I did have to push the Bull 4 blocks home one day. I kept looking for the magic code from the check engine light but nothing ever came about the pump. One did come indicating the fuel pump driver module. I did get another one of those at a wrecking yard but that didn't do it. ($24) I did tackle the pump job myself from instructions from a Haynes book. The Ford dealer estimated my job at $1200. I figure I would be stupid to sink that much $$ into the vehicle. Is a tedious but not difficult job. If you shop around can get the part for about $200, I found a Carter (made USA) for $175 so it is worth the effort to DIY. By the way, it was my problem.
Old 03-02-2010, 03:14 PM
danielsatur danielsatur is offline
How old is the battery?
Old 03-02-2010, 03:23 PM
2 months old.
Old 03-02-2010, 03:28 PM
Make sure connections are clean + tight!
Old 03-02-2010, 03:30 PM
Originally Posted by Willyum View Post
Jens,
Willyum
That's good advise. I did find one on the net for around same price. How long did it take you to complete the job?
Tjensen
Old 03-02-2010, 03:33 PM
Thanks for the advice. I'll double check.
Tjensen
Old 03-03-2010, 12:06 PM
How long does it take to do the pump at home?
Getting the tank out took the longest. Securing the rear up on stands takes a while, you don't really need it up real high, but high enough to be able to lower the tank with a floor jack. I took off both rear wheels, be sure to take the right one off for sure. The hoses are stuck on tight, need to be careful not to damage them, most are not off the shelf generic hoses. Probably took me 3 hours off and nearly that long back on. I took my time and cleaned the top of the tank well. Also, I don't think you need to have the tank any more empty than 1/4. Actually could do it with more but it would be hard to handle.
By the way, should you DIY, the instructions how to do the whole job came inside the Carter fuel pump box.
Old 03-03-2010, 12:12 PM
Isn't there an access hole for the fuel pump under the rear seat?
Old 03-03-2010, 01:47 PM
-Rod
Rod
Is there any special tools needed to change the fuel filter?
Tjensen
Old 03-03-2010, 01:51 PM
I really don't know. Does anybody else know about that? It would surely save some time though.
Old 03-03-2010, 01:56 PM
Thanks again Willyum.
Old 03-03-2010, 01:59 PM
www.alldata.com is worth every cent!
