Old 03-01-2010, 06:59 AM
bearcatdon bearcatdon is offline
Electrical shut down at start up
I have a 2004 Cavalier with 80K and the 2.0 Eco. When I turn the key to the accessory position all dash lights come on and the radio shows the correct time. Once I turn the key to start the engine everything dies as if I disconnected the battery (radio will now be set to 12:00 due to power loss). I pull the key out let it sit for a few seconds and try again. Sometimes it starts immediately other times it takes 4-5 tries. Any clues?
Old 03-06-2010, 07:41 PM
jdl jdl is offline
Re: Electrical shut down at start up
I'd have to make sure the battery has a full charge and the connections are good. With the key in the crank position, what are the dash lites doing? Are they on or off, anything?
Old 03-12-2010, 07:11 AM
It turned out to be a loose connection on the battery. It obviously had enough of a connection to give me juice but not enough under full load. Battery was tested and had no issues.
