Old 02-28-2010, 06:52 PM
davem5761 davem5761 is offline
Brakes dragging
While i was driving, I noticed my car was a little sluggish, and the steering wheel began to shake, when i got were i was going (about a 10 mile drive) there was a real strong smell coming from the brakes, when I got out of my car the front driver side brake rotor was smoking. I'm going to assume the wheel shaking came from the rotor warping. I haven't had a chance to look into it yet. Any ideas why the brakes would drag on just one wheel?
Old 02-28-2010, 06:53 PM
Re: Brakes dragging
The car is an '01 GT
Old 02-28-2010, 07:13 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Brakes dragging
take the calipers off and check the pins. Alot of times people do not re-grease them after doing a brake job, and they cause the caliper to stick
Old 02-28-2010, 07:44 PM
rickisrad rickisrad is offline
Re: Brakes dragging
Also make sure the rubber bushing on the caliper slide pin is not swollen and hard to slide in and out. Napa carries those for a few bucks. Another thing is to make sure the pads are not extremely tight in the bracket. I have seen a lot of pads that had to be hit out with a hammer because they were either seized to the hardware or they just did not fit right to begin with. Sometimes you have to grind a little paint off of the edge of the brake pad backing that slides into the bracket.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
