Old 02-28-2010, 04:08 PM
toycam toycam is offline
97 3.3 caravan intermittent dies
hello i am working on a 1997 dodge caravan se 3.3 v6 auto. scanned no codes live data everthing is in spec.power and fuel pump relays tested good.tap test on underhood computers checked ok.this is what i have done.the vehicle runs and drives fine but intermittently it will just die then will take anywere from 10 minutes to 30 minutes to restart just cranks. and it does it aprox 5-10 times throughout a full day of driving.if any one that knows there dodge vans might have a idea let me know would apreciate thanks
Old 02-28-2010, 06:27 PM
tempfixit tempfixit is offline
Re: 97 3.3 caravan intermittent dies
Have you checked the cam and crankshaft sensors?
Old 02-28-2010, 10:08 PM
they ohm test ok and seem to be working when viewing live data on snap on 2500 scanner.thanks for quick reply .any other thoughts
Old 03-02-2010, 11:12 AM
kpa2004 kpa2004 is offline
I had the same exact problem, I cleaned the MAP sensor and problem went away, I also changed the plugs, but,the problem was still present. When it did it, I would be driving, (steady state operation), and the van would like skip once and catch itself and run normal for a while. Then once in a while it wouldnt start on the first try and it triggered the code for the MAP sensor,thats what made me clean the map sensor,i'm too cheap to buy a new one, But anyway the problem went away after the map cleaning. There is also a service bulletin for the knock sensor for what seems to me as the same symtoms as I had and the problem you describe. It tells you to remove the knock sensor altogether and stow the wires, I did that before anything but it didnt solve the problem, so I restored it to original configuration. So clean the map sensor or replace it see what happens.
Old 03-09-2010, 06:15 PM
rustbucketbronco rustbucketbronco is offline
My 2000 started doing the same thing just yesterday. Where is the map sensor located? In case that doesn't work where is the knock sensor? Thanks for your help.
Old 03-09-2010, 08:20 PM
MAP sensor is on the intake plenum right above and aft of that tree of vacum lines, on the right side of the engine. The knock sensor is on the left front side of the engine block above the oil pan and to the left of the oil filter. All are as viewed from the front looking aft.
