Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-28-2010, 03:07 PM
breakerbar's Avatar
breakerbar breakerbar is offline
Door pin replacement
Hi:
I would like to change the door pins and bushings on my 2006 gmc sierra. I was wnodering if I would cause any damage if I used my air chisel to get the old ones off. I was also thinking about a sawsall, or grinder if it fits in there. This truck has a nut and bolt type replacement pin system and the original ones are similiar but I think they look rivited or something to that effect. Getting them off is going to be the hardest part. Good thing I only have to do the drivers door
Thanks
Mike
Old 03-02-2010, 03:48 PM
2000CAYukon 2000CAYukon is offline
Re: Door pin replacement
I am not sure if this will help or not http://www.bodyshopzone.com/archives...replace_1.html
//2000CAYukon
Old 03-03-2010, 08:42 AM
breakerbar's Avatar
//2000CAYukon
Thx for the info but my pins are different. They are about an inch and a half and have a the bottom of the pin has a nut to hold it. There are 1 pin for the top and pin for the bottom of the hinge. A total of four per door.
Thanks
Mike
Old 03-04-2010, 03:22 PM
Thanks
Mike
This one should help: http://www.totalauto.com/presentation/index.html
//2000CAYukon
Old 03-07-2010, 10:38 AM
breakerbar's Avatar
[quote=2000CAYukon;6117642]This one should help: http://www.totalauto.com/presentation/index.html
Thank-You for the hard to find step by step video 2000CAYukon. I really appreciate it. Just what I was looking for.
Sorry it took so long to respond to your post, but I had broke a finger on my Right hand. YES.... my index one too!!!!
I guees that means I won't be doing the door pins any time soon.
I hope a mod reads this and adds both you links to the stickys.
I really do not see much on door pin replacement even on the internet. I bookmarked the vid for future use anyway. Great stuff!!!
Once again thanks a bunch!!!
Mike N
Old 03-08-2010, 12:02 AM
Hopefully, your finger will heal quickly so you can get those pins replaced. Let us know how it turns out.
//2000CAYukon
Old 03-08-2010, 07:43 AM
breakerbar's Avatar
Thx.
Will do...
Mike
Old 03-12-2010, 12:43 PM
Hired Goon's Avatar
Hired Goon Hired Goon is offline
Thanks
Mike
On numerous occasions I had to drill the bushing holes on a pile of these vehicles and go with oversized pins and bushings, hope yours is not to bad yet as this is a PITA because of the four pins, I guess the two pin idea was to good to keep using
Every mile is a memory, make it a good one
Old 03-12-2010, 07:18 PM
breakerbar's Avatar
Thanks for adding that info Hired Goon. I know that they are not worn into the bracket yet. I still need sime time to heal my broken hand. I will keep an eye on them and if need be I will be forced to take it to my local body shop to have it done.
Again Thanks
Mike
Old 05-01-2010, 05:12 AM
Mycrofte Mycrofte is offline
Thanks for all the info! I had to replace mine last year (1997 Sierra) and they are a pain to get back in. Would have been easier if it was a straight line shot to hammer them back in.
If I had access to a machine shop I would have made custom C clamps to press them in instead of drilling like "Hired Goon" did...
