Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 02-28-2010, 01:14 PM
Fordexpedition Fordexpedition is offline
2001 Lights stay on when ignition is off, won't turn
Yesterday was driving and the dash warning lights (4 x 4 and windshield wiper) were flashing on and off randomly. At each flash, the windows would hesitate while being rolled down. Short?
I turned the ignition off and this morning the battery was completely dead. I tried to jump it but the healights (and high beam dash light) would remain on with the keys out of the ignition and the lights turned off.
I then found that the starter relay fuse had blown, which I have replaced. I think it will start but the problem is not the fuse itself. Is there a relay that may cause this? The owner's manual does not show one!
Within the last 3 to 4 weeks I had my TV, laptop and now my ford burn out to electrial problems, what are the odds??
Thanks for your help and always count your blessings!!!
Old 03-14-2010, 06:47 PM
exitRooster exitRooster is offline
Re: 2001 Lights stay on when ignition is off, won't turn
I'm new to Fords, been a long time Jeep Grand Cherokee man, and GM car guy.. I wanted to ask about your lights, ya said they stay on when you remove the key.. Does your Expedition have the message center deal? (again, I don't know jack about the various years/options) - If so, there is a setting I know to set the length of the headlights to remain on after you stop (IE remove key, close doors, lock em, etc).. Maybe that's just set to the max? Or do you mean like, they stay on alllllll the time.. Have you tried various headlight switch positions as well? IE, not just in the auto-lamp mode? Light-wise, those seem like possible causes.
The interesting part was about the other warning lights coming on. Generally if there is a short, it would only affect one or a few related systems, such as say, fuel gauge bouncing down to empty and back up (which I actually had that short on my Jeep once), or other related issues.. I wouldn't think two random things like 4x4 light and wiper fluid low light would be 'near' each other anywhere where one short would affect both systems. Are the fuses near each other? Perhaps water/moisture got into the fuse box or something? Or again, since I really don't know much (just trying to help by throwing some ideas out there) maybe all that crap rides together in one electrical harness and is in fact shorting out somewhere! Let us know what ya find.
Last edited by exitRooster; 03-14-2010 at 06:48 PM. Reason: edited for numerous spelting issues! :)
Old 11-19-2012, 04:55 PM
lklekas lklekas is offline
The problems everyone is having is caused from corrosion in fuse block.Water leaks in from windshield,window etc. And then collects at bottom of fuse block.There is no drain.U must remove and Ethier clean or replace box.Not a job 4 most.It took me the better part of the day 2 complete.Drill a 3/16 hole in each corner for drains.
