Old 02-28-2010, 12:57 PM
sloppydawg123 sloppydawg123 is offline
Engine won't switch to closed loop, need help
I have a 97 4.3 vortec, and it never closes the fuel loop. Also it is running lean in the open loop according to the o2 sensors. The truck hesitate when first trying to accelerate and the idle moves around a bit, but runs fine other than that.
What makes the fuel loops close?
Old 02-28-2010, 03:09 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Engine won't switch to closed loop, need help
Engine tempt going to normal 195 and 02 sensors kicking in full operation.
Fuel pressure good?
Any codes or check engine lights?
Mileage and last tune up?
MT
Old 02-28-2010, 04:08 PM
Haven't checked fuel pressure, was trying to figure this part out first. I just bought the truck, only 86k miles, has new plugs cap and rotor. Engine temp going to around 190, and it has the code for no activity on o2s21.
The scanner reads
o2s11 .05
o2s12 .0215
os213 .400
os221 .440
All of the st and lt ftrm are always 0% and it says fuel system 1 and 2 are always open
Old 02-28-2010, 06:15 PM
777stickman 777stickman is offline
Keep in mind that what you read for engine temp on the dash comes from a sensor in the drivers side head. What the VCM sees for engine temp comes from the ECT sensor which is close to the t-stat housing.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 02-28-2010, 06:43 PM
There was a cut wire in one of the o2 lines, reconnected the wire, cleared the codes, fuel loop closed as they should. Thanks for the replies
Old 02-28-2010, 06:57 PM
j cAT j cAT is offline
I would replace the O2 SENSOR slicing these wires causes problems with proper engine performance..
Old 02-28-2010, 07:07 PM
well, the cut was in the wiring harness side of things, not the wires off the sensor, so for now i'll just see how it runs and proceed from there
