Go Back   Automotive Forums .com Car Chat > Dodge > Durango
Old 02-27-2010, 04:39 PM   #1
phantom1131
Intermittent No Start 2003
2003 Durango, 4.7, 4wd,162000 miles
new fuel pump and battery
I have searched the forum and think the computer or ignition is bad,would like some opinions..here are the symptoms
can be hot or cold, seems to happen more when moist or damp weather conditions...everything works accept gauges and fuel pump when this no start happens...getting no bus on dash...tried code read with key on/off 3 times ,it says P done,wiggling wires to computer does not help
when i hook cables to jump or to charger/starter it fires up...seems like just a shock is all it needs
phantom1131 is offline   Reply With Quote
Old 03-01-2010, 08:15 AM   #2
2000izusu
Re: Intermittent No Start 2003
no bus means the sensors are not communicating with the pcm. just one shorted sensor (on the bus) can bring it down. next time it happens unplug one sensor at a time and when no bus goes away that is your problem sensor. if that doesn't work then pcm could be the problem.
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
2000izusu is offline   Reply With Quote
Old 03-01-2010, 12:18 PM   #3
phantom1131
what sensors are on the bus?..or should i ask is there any that are not
anybody have a sensor location diagram ??
Old 03-01-2010, 06:59 PM   #4
phantom1131
ok, when the thing is running and i tap or push on the 2nd pcm connector the engine quits if done hard enough or just studders with light tap or push
Old 03-02-2010, 12:23 AM   #5
hundahunta
pcm...7/70
hundahunta is offline   Reply With Quote
Old 03-02-2010, 12:35 AM   #6
phantom1131
Originally Posted by hundahunta View Post
pcm...7/70
what are you saying??
Old 03-02-2010, 06:50 PM   #7
phantom1131
here is the latest.....when in no bus mode and key left on while i am checking different sensors and stuff, after 10 -15 min. you hear the fuel pump kick in and gauges work and all is good to go.
also when driving....radio,heater fan,dash lights etc.. are losing power very briefly...not going off but fan slows, radio blinks, dash lights dim
i think i am going to get a new pcm and see what happens...just can't find anything wrong
Old 03-04-2010, 12:09 PM   #8
2000izusu
before you do anything read this thread cover to cover. some symtoms match yours (such as wiggling the pcm connector) Mike
Link:
http://www.automotiveforums.com/vbul...control+module
2000 rodeo SOLD
Old 03-04-2010, 01:12 PM   #9
phantom1131
i have allready read that and looks like most of them replaced the pcm...thanks anyway
Old 04-12-2010, 12:56 PM   #10
GirlBear
GirlBear's Avatar
Did you ever figure it out? My issue was the main fuse in the box of fuses under the hood on the druver's side.
http://jowulf.deviantart.com/
GirlBear is offline   Reply With Quote
Old 04-12-2010, 01:04 PM   #11
phantom1131
I replaced the PCM and so far no problems
Old 01-02-2011, 06:58 PM   #12
phantom1131
Here we go again...just started doing it again
Old 01-04-2011, 03:50 PM   #13
phantom1131
checked everything again and came up with nothing...this time after about an hour or so with key left on while checking everything it took off and started...
left it overnight, went back today and no bus again....unplugged all the sensors and again after an hour or so with key in the on position it was good to go even with all the sensors unplugged..
the reman pcm i put in back in march took care of this issue...no problems until now with a little over 12,000 miles logged since
what are the odds the pcm failed again?
if it is pcm again what is causing constent failure??
any thoughts would be appreciated
