Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-27-2010, 03:25 AM
Echos Myron Echos Myron is offline
Strange steering symptom
My '98 Tahoe's steering has been giving a strange feeling during soft right turns, as on a highway cloverleaf. There is a slipping sensation, as if I might lose all steering control. This doesn't happen during left turns at all, nor does it occur during hard right turns, as in simply turning a corner. Any ideas? Thanks.
Old 02-27-2010, 11:18 AM
777stickman 777stickman is offline
Re: Strange steering symptom
It is most likely what is commonly refered to as the EVO sensor. Its real name is Steering Wheel Speed Sensor and is part of the Variable Effort Steering system. It is located at the base of the column before it goes thru the firewall.
To confirm that your Tahoe has this system look for wires going to the lower rear of the power steering pump. If this system is not installed then your trouble is most likely mechanical.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-05-2010, 03:36 PM
sprucegoose's Avatar
sprucegoose sprucegoose is offline
Yes, i agree with Stickman as I had exactly the same symtoms on my 98 and I swapped out the EVO steering sensor and all is good now. See my post http://www.automotiveforums.com/vbul...d.php?t=976080
It is just a donut shaped electronic sensor that wraps around the base of the column. Not tough to change, just a little cramped under the dash of course. Drives like a new truck now. Good luck!
~Dave~
'08 Chevy HHR SS, Victory Red, 5 spd. 2.0L Turbo, 52K mi.
'98 Buick Riviera, Black, 3.8L Super-Charged, 228K mi.
'98 Chevy Tahoe LT, 5.7 Vortec, Black 241K mi.
'70 Pontiac Firebird Formula 400, 4spd 200k+ mi., in process restoration
'10 Dodge Grand Caravan SE, 11K mi.
Old 03-10-2010, 09:48 PM
jermiester1 jermiester1 is offline
Same comment as the others. I suspect your problem is the steering EVO sensor. In 135K miles I've had mine replaced a couple of times (99 Tahoe). Feels like a jerk or twitch in the wheel when your turning.
