Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-26-2010, 09:30 PM
ldm376 ldm376 is offline
V-tec problems/engine bogs down before redline
hey everyone. i'm new to the forum and hope someone can help me out. when i try to utilize the v-tec (which we all know was the reason we got our preludes) the engine acts normally until it gets to about 5 and a half. then... nothing. it just continues, until it almost gets to redline, then stops and bogs down as though i'm redlining it. it has nothing to do with the oil, or oil pressure (I don't think) because i tried it right after getting an oil change.
things you should know about the car: it's a 1998 5 speed type SH, with a (necessary after purchasing, fuck you to the guy who sold me the car) engine swap. i THINK, but am not sure, that the engine is an H22A from a Canadian accord. it's a red top. after the engine swap, everything went well... at first. then the VTEC stopped working. also, after the oil change, the VTEC would work shortly, then stop. it also worked after my mechanic monkeyed around with the carburator a bit. it also works (very very seldomly) spontaneously... can anyone help? has anyone ever had the same problem? thanks so much for reading!
Old 03-05-2010, 01:50 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Re: V-tec problems/engine bogs down before redline
Might be the ECU. EDM engines require a different ECU I think. Might be a fuse or relay as well. I'd bring it back to who you bought it from and go crazy.
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Tags
redline , vtec
