Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-26-2010, 07:13 PM
ager803's Avatar
ager803 ager803 is offline
'02 ram 3.7L issues
working on a ram 3.7 with 120,000 miles on it, has a bad misfire and pocket scanner gave me a p0306 code (#6 cyl. misfire) . replaced plugs and coil but still no remedy. checked compression and gave me a low reading compared to the other 5 cylinders. they read at 150 psi and the #6 read at 80-90 psi.
anybody else have this problem? and will i have to replace the piston rings at my cost or is there a TSB or recall or something about this.
this truck has low miles IMO for this to happen.any help or advice
Old 02-27-2010, 04:54 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: '02 ram 3.7L issues
Is there exhaust smoke?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 03-01-2010, 07:18 AM
2000izusu 2000izusu is offline
it is most likely not the rings, but is probable a burnt valve. was the truck "short tripped" and did the owner use cheap gas with the epa minimum detergent?
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
