Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-26-2010, 04:02 PM
crobar1 crobar1 is offline
Old 77 Chev settings
Just been given a 1977 Chev 1/2t pickup with 350. I am putting in a new timing chain kit and plugs among a few other low cost items. What I need to know is what gap are the plugs,points set at and what would be the suggested timing?
Thanks
Old 02-26-2010, 04:31 PM
777stickman 777stickman is offline
Re: Old 77 Chev settings
Thanks
'77 chevy motor should have an HEI dist. (No Points) Plugs gaped at around .045. Timing set at around 8 degs BTDC.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-02-2010, 05:51 PM
j cAT j cAT is offline
Thanks
I looked this up, the timing is 8deg BTDC . the plugs are R-45ts with a gap of .045 .
starting in 1975 the points were removed , this has a more powerful ignition spark than the pre 75 engines...you should replace the wires also if they are old ...take care in how you run these wires ..
I would also replace the fuel in carb filter ..the fuel pressure should be 7-9 psi..idle 500-600 rpm...when adjusting the timing follow the sticker instructions if you can still read it..
before timing the engine get some white chalk and mark the timing dial then put some on the harmonic bal. mark...this will make this very easy to see..
