Old 02-26-2010, 01:46 PM
ulremember ulremember is offline
03 Silverado stalls during stops
Hello to all. I have a friend that removed his battery to work on his other pick up. Battery was out of vehicle for about two hours. He reinstalled the battery and now the truck stalls during stops. Off idle, truck runs fine. Will only start if you give it a lil gas. I am thinking it may be the IAC trying to "reset" itself. It only stalls during
'off throttle" stops. Seems like no fuel or too much air which leads me to think of the IAC. Is there a procedure for resetting the IAC. I think I recall driving at a rpm of about 2500 r's but I am not sure.
Any suggestions are greatly appreciated.
Thank you in advance
Charles Butler aka ulremember
Thanks to all!
ulremember aka Chuck Jr.
Old 02-26-2010, 05:04 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 03 Silverado stalls during stops
There is a certain drive cycle to reset it.
But try to.
Take it for a good long drive and run at different speeds.
Let us know how it goes.
It should reset itself.
MT
Old 02-26-2010, 05:46 PM
j cAT j cAT is offline
removal of the battery for any length of time should not effect the idle...as far as the re- learning this will not effect the idle ..The IAC does not need to be reset unless it was removed and the valve was rotated which is a no no....
with this issue I would look at the MAF wires/air ducting or any other wires damaged/disturbed during the battery swap out...
check all fuses just in case !
Old 02-26-2010, 06:01 PM
rottonrattt's Avatar
rottonrattt rottonrattt is offline
try some good old throtle body cleaner.somtimes carbon on the butterfly valve will cause this
Old 02-26-2010, 08:50 PM
Hello to MT-2500 and all.
MT-2500 sold the burbie with 4L80. The one with no shift.
As for the Silverado I posted about, I will have him take it on the freeway and drive. I told him that yesterday.He is Not a "good one footer" let alone two footer" driver. LOL
I will also inspect the butterfly and wiring. We cleaned the contacts on SIDE POST battery. Told him to switch over to top post. Red Top Optima Battery is installed and charged.
Funny thing is,a ll he did was take it out, I was there supervising . Other problem was that the other truck is a v6 and getting the pressure side power steering hose is a bugger. Super tight. cut the line to get socket on it, not moving. So tomorrow we are gonna take off the the pulley and pump and get er' done.
Thank you again for the replies and I will keep you posted.
How ya been MT? I "retired" from busting knuckles pretty much
Thanks to all!
Old 02-26-2010, 08:51 PM
Also HEY jCAT! I did not see your name in the reply. How have you been?
Still remember how much help you and MT and a couple others gave me. THANK YOU AGAIN!
Thanks to all!
Old 02-28-2010, 02:07 AM
Took truck on freeway and drove about 4 miles. Took her on a nice side street and drove pretty hard. Runs like a champ now.
Thank you again for the replies.
Blessings
Thanks to all!
Old 02-28-2010, 08:38 AM
MT-2500's Avatar
AF - Advisor
Blessings
You are welcome and thanks for posting back how it went.
Glad it worked out and is running good.
Remember.
When unhooking or changing or replacing a batter always unkook neg firsr and hook it back up last.
Good luck
MT
Old 03-04-2010, 12:39 PM
Thank you MT! He had asked me about the cable replacement order. I did not think it mattered.
Blessings to you and the family!
Chuck aka ulremember
Thanks to all!
Old 03-04-2010, 01:20 PM
MT-2500's Avatar
AF - Advisor
You are welcome.
Yes if battery is not unhooked and hooked up right you an spike VCM.
Good luck
MT
