Old 02-26-2010, 08:50 AM
cfl3794 cfl3794 is offline
Leak Down Test
when performing a leak down test how will you be able to tell if you have a cracked head or blown head gasket?
Old 02-26-2010, 10:32 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Leak Down Test
You should hear/feel the air coming out of the adjacent cylinder's spark plug hole.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 02-26-2010, 10:07 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Leak Down Test
It all depends on how it's blown, and/or cracked. Often, you will get the cooling system start to pressurize (the rad hose gets firm, or if the rad cap is off, bubbles come out. )
Sometimes a blown HG will leak to an adjacent cylinder or to the crankcase. Sometimes a head that's cracked around a valve seat will push air past an intake or exhaust valve (although this is more indicitive os a burned/leaking valve).
So, generally, you can confirm a blown HG or cracked head in this manner. But an absence of such symptoms does not exclude the possibility of a problem.
Old 03-03-2010, 02:50 PM
danielsatur danielsatur is offline
Re: Leak Down Test
A good 100psi on each cylinder under test should be good!
see www.youtube.com/watch?v=jG_RWs8ckp4
