Old 02-25-2010, 07:29 PM
mybad_z71 mybad_z71 is offline
rear diff fluid frothy?
hey guys another question bout my 97 z71, after running the truck thru the gears while rear was on jackstands before i removed the rear driveshaft (for noise identification) i decided just to go ahead and remove the rear diff cover, i just bought the truck and was going to change all the fluids anyway, when i pulled the pan all the way off the oil looked so frothy, like i ran it through a blender, what causes this? there were no leaks on the diff or the seals.
Old 02-25-2010, 09:14 PM
j cAT j cAT is offline
Re: rear diff fluid frothy?
the rear diff fluid should be dark and of a thick viscosity..If its whitish looking and thin this may mean the vehicle was run in very deep water, also the diff venting must be intact , and routed correctly..on a 1997 not sure how this was routed ..
I would put regular engine oil in it to flush it then using rags with paint thinner [mineral spirits] wipe in down best you can and use a air compressor to blow it out ..
the wheel bearings may after some time , give you trouble , if the water got to them ..
Old 03-12-2010, 08:59 PM
well, turns out both pinion bearings were chewed, i just had my rear end rebuilt and the noise is gone now for the brake issues, if anyone has ideas please see my other post bout the brakes, thanks guys.
