Old 02-25-2010, 03:57 PM
kgriggs75 kgriggs75 is offline
need confirmation of my thinking
1996 k1500 5.7 auto 175000 miles. a couple of months ago the truck started being hard to start. before turn the key it fires now you have to crank for 5 to 10 seconds. there is a misfire that started. the exhaust note on the passenger bank sounds different. i changed the plugs and two on that side smelled of fuel but were otherwize normal. i checked the fuel pressure and its 57 cold and hot and running but if i cut the key off it imidiatly drops to 20 where it holds for a few minutes before going to zero. I am thinking the regulator is shot and that the fuel pump is getting weak. I am planning on replacing the regulator this weekend as i need to do the intake gasket anyway.
sound about right to you gurus?
2006 Chevy Uplander ls 3.5 128,000
1997 Buick Lesabre 3.8 and 135,000
1996 Chevrolet K1500 5.7 185,000
plus a 66 belair 65 gmc 70 c10 and a ford
Old 02-25-2010, 11:20 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: need confirmation of my thinking
Sounds good to me. I too went through that, although now it seems the pickup is running lean and still losing fuel pressure, so in the tank I come!
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-26-2010, 01:08 AM
consultIII consultIII is offline
also...might be check valve in the fuel pump. shut it down and immediatly clamp off the return and see what the fuel pressure does.
Tags
fuel , hard , missfire , pump , start
